Liquid Gingerbread v3.2, softkeys failing to light...
falkon114
6
Just installed LGB 3.2 on my HTC Thunderbolt. the soft keys light up until i turn the screen off and then on again, and will not light back up unless i go to display settings and manually adjust the slider in any increment, they will stay lit until the screen is off again, and then the same thing happens. is there a fix, or is this just how it will be?
Thanks! other than that, it's a fantastic ROM so far
Markizta
