I took my extended battery out (had 75% life) and replaced it with the original battery I had (which has been sitting for a couple months).
The first thing I did was plugged it in. I got an amber light for about 10 seconds then it went out and nothing. It will do this every time I plug it in. However, it would not turn on.
So, I put my extended battery back in, and now it does the same thing -- plugged in, amber light for ~10 seconds, then it goes out. Can't turn it on.
The extended battery should work fine. I don't know what the problem is.
Anyone know what to do?
