Hi everyone I was wondering if there is a way to get apps onto an SD card now that it seems Google has restricted it. Also if there is a way to get Downloaded$$ Music(from amazon) onto the SD card. I have 250 apps from Amazon and probably 50 from Google market but none can be transferred to SD card and neither can the music I purchased. Instead it says "Move to Media Area" which is just another area of internal phone storage. And that filled up quick. Went to verizon and he said all the new phones were like this,he figured that out AFTER he wiped my phone clean.Thank you. Droid X2.
300 apps? What could you possibly be doing with 300 apps? You might want to consider not reinstalling some of them, and, only installing what you need. I get the free app from Amazon every day, but, I never install it, just "purchase" it. I have the option to install whatever app I want whenever I want, so, unless I'm actively using it, why bother having it installed.
I assume most of the 300 apps are games? You can't be playing that many games, just install what you are currently playing. If you want to keep your save data, you should be able to copy the folder from storage to your computer before you uninstall it. You can test it out with some data you aren't really concerned about, but, I have had success with it in the past.
As moosc said, whatever storage space you have dedicated for apps should be plenty. I think you just need to make sure you do a little routine maintenance and house keeping every so often. I have a weekly calendar event setup that reminds me to uninstall apps I don't use, and, do some general phone maintenance. You might want to do the same.
