1. bgswis's Avatar
    I bought a Cricket ZTE Score from Best Buy last month and added some apps from the market. Then I reset the phone to delete the apps on it and returned the phone for a refund.
    Now I bought a Samsung Intercept and when I go to the market to add apps it shows both the Samsung and ZTE phones for my Google acct. Can I remove the old phone I returned from Android market?
    I am considering returning the Intercept and getting an LG Optimus V instead. I don't want my Google android market to fill up with old phones I no longer have.
    12-13-2011 09:59 AM
  2. CansFan's Avatar
    I've been trying to figure this out myself and haven't found a way...tried google for answer and there doesn't seem to be an option to remove phones at this moment.
    01-12-2012 10:48 PM
  3. 2ndaccord's Avatar
    You can't but you can filter so it won't download or shows apps that phone.
    Sent from my SPH-D710 using Tapatalk
    andreo likes this.
    01-12-2012 11:08 PM
  4. Dixie's Avatar
    Try this (no guarantees):
    Log into Android Market https://market.android.com/ (easier for me on computer)
    Click the gear in the black bar, upper right next to your email address, and click "My Market Account"
    Click on tab for "Settings." For me, my device is listed there.
    It was a few months ago, but I was able to un-associate my son's phone from my account. (Prior to buying my phone, I had used his phone to set up a few programs I knew I would be getting. Later I was able to remove his phone from this list.) It has to be there somewhere. Good luck!
    bgswis and ScandaLeX like this.
    01-13-2012 04:17 AM
  5. Devinator's Avatar
    Yea, it looks from within Settings, you click Edit, then Hidden in Menus and that should take care of it. Someone in this link seems to think so anyway.
    "Ok SO the only way to do this right now is to go to https://market.android.com/account then go to "Settings" which is next orders (not up by the sign out link and the other links) it will then take you to a screen of your devices. Then click "Edit" on the device you don't want to not see anymore and then click under the visibility column "Hidden in Menus". This will remove the option to send apps to that phone, and will remove apps that were downloaded to that phone from showing up."
    https://groups.google.com/a/googlepr...et/aRyG0PZTrzE
    01-13-2012 06:58 AM
  6. bgswis's Avatar
    Thanks for the replies. I went to settings and chose "Hidden in Menus" for my ZTE score and that worked. It no longer shows up as one of my devices when I try to install apps from the market.
    However, I have a second phone I no longer own, Samsung intercept. When I chose "Hidden in Menus" for that it worked, but the ZTE score changed to "shown in menus". I went back and changed the ZTE to hidden, and it changed the Samsung to shown. So it only lets you hide one device.
    01-13-2012 09:47 AM
  7. Devinator's Avatar
    Are you doing them in the same session? Try changing one to hidden, then logging out, then back in, see if it's still hidden. It seems like people are having issue with the change sticking.
    How to delete old Android Device from my Google account? - Gmail Help
    01-13-2012 10:22 AM
  8. bgswis's Avatar
    I changed one to hidden, then logged out, then back in but it didn't help. One is still hidden but when I change the other one to hidden, it changes the first one to shown. I can only hide one device.
    01-13-2012 02:50 PM
  9. Devinator's Avatar
    Wow, that's really lame. I guess the only thing left to do is to contact Market Support. Probably wont accomplish much, but, I guess the more people that complain about it, the sooner they'll have to address it. I guess hide whichever device you prefer for now, and contact support.
    bgswis likes this.
    01-14-2012 08:52 AM
  10. RobertyBob's Avatar
    This is INSANE.
    I have been with Google since Day 1 almost, and I can't believe they haven't set this up better.
    You can't delete a phone or block it from accessing your Google account??
    What if it is stolen? what if you resell it?
    I've been busy googling this and trying to find a way to block old phones so no one can download on your account with a phone you previously owned.
    GOOGLE DO SOMETHING!
    03-08-2012 11:36 PM
  11. ScandaLeX's Avatar
    This is INSANE.
    If you resell it I hope you would wipe it first. That person would be accessing the market under their gmail acct; not yours.
    In the event it's stolen, I'd suggest calling your carrier immediately & or remote wiping your phone & SD card.
    I've given plenty of phones away. Having them still listed doesn't matter to me since those phones aren't tied to my email any more.
    Sent from that phone with the REALLY long name using Tapatalk
    03-09-2012 12:34 AM
  12. Devinator's Avatar
    Sure there is, change your Google password. Then if it were stolen, whoever had your phone shouldn't be able to access Market, or, do anything else with your Google account.
    If you resell it, do a factory reset first and they'll have to supply a Google account when setting up the phone. So, it wont have your information.
    03-09-2012 08:37 AM
  13. Mustachio's Avatar
    Just create a new Google account and use that to access Market. It won't have any of your old phones listed.
    03-12-2012 07:33 AM
  14. Devinator's Avatar
    That's not what we are talking about. OPs concern was if they sold the phone, lost it, or it was stolen, that it could have access to their account. I think all the posts in here should solve their issue.
    03-12-2012 08:16 AM
  15. nikunj715's Avatar
    Logon to https://play.google.com/store/account
    On the right corner you will see your login name and a bearing image which says options
    On the options link you will see "My orders and Devices"
    Click on Devices and then check/uncheck your desired phone
    03-28-2012 02:36 PM
