Results 1 to 5 of 5
    Question How to put android 2.3.3 or higher onto a ZTE t3020 aka ZTE Racer
    i have a ZTE T3020 from Telstra in Aussie and i am tired of android 2.1 how can i update it with genuine roms if possible
  2. #2
    pazzo02's Avatar
    Posts
    ROM
    Sabsa Prime ICS
    Default Re: How to put android 2.3.3 or higher onto a ZTE t3020 aka ZTE R
    Probably the only way you'll be able to get Gingerbread is to root the device and install a custom ROM.
    am i able to put any version higher on it??
  4. #4
    pazzo02's Avatar
    Posts
    ROM
    Sabsa Prime ICS
    Take a look at this forum:
  5. #5
    Hi Can u please explain the procedure for upgrading android 2.1 to a higher version...onto T3020...As i'm not much familiar with this kinda
    Thanks
    Manish
