 Thread Author
# 1
12-15-2011, 06:26 AM
Member | | | Join Date: Oct 2011
Activity: | |
adb logcat bootcamp I'm going to be teaching the basics of logcats. I sat for a few hours a while back and hammered all this stuff out with ckisgen from XDA/ACS holding my hand the whole way, so this is good info here. I did the whole thing in Ubuntu (Linux) and have listed the Window$ $pecific desktop pathing below the Linux command. UNIVERSAL COMMANDS LINUX COMMANDS WINDOWS COMMANDS. When I say Terminal, I mean Command Prompt for you Window$ u$er$ (start-run-cmd) In terminal with your phone plugged into the computer A Logcat: This doesn't START logcat, this tells terminal to grab the information already on the device logcat and display it in terminal. This isn't so useful to us. It just scrolls the information in terminal and you can read it there. This is kinda difficult to read though, for one it's constantly scrolling as your phone does things and two, it's likely that your terminal is configured to only allow a certain number of lines to be kept readable before they drop off. Pipe it to Desktop as a .txt file Code: adb logcat > ~/Desktop/logcat.txt
adb logcat > %userprofile%\desktop\logcat.txt This command above will tell the logcat to export the terminal logcat to a .txt file on your desktop called logcat.txt The '>' symbol tells the logcat to pipe to the location listed. This will continue to update even if you open the text file, so long as you have terminal running. It's not done “live” though, you have to either refresh the file, or close it then re-open it. That won't affect anything other than giving you an update. Now we're getting somewhere, but where? Code: adb logcat > /sdcard/logcat.txt If using Terminal Emulator on your phone instead of a computer setup, this (above) is the code you'd want to use. It will save the logcat.txt to the root of your SD card. Next! -v long, or not to -v long, that is the question! Code: adb logcat -v long > ~/Desktop/logcat.txt
adb logcat -v long > %userprofile%\desktop\logcat.txt Now we're telling the logcat to do something more interesting. We are telling it to give us every scrap of information it has. This will space the logcat out nice and pretty and really make things easier to read as well, even giving time stamps of when everything happened! Now you can say “it happened at about 9:30 pm” and we can find that. Winning! Sometimes you want to filter down the information though. You want to make the dev's life easier. Here is how: First, a brief on Tags and Priorities. Tags are going to be what process is actually giving the information, for example 'ActivityManager', 'Database', and 'WindowsManager' are all Tags you can find. There are TONS of these suckers! Research into what your problem is and try to pick out the tag. Priorities are different. These will tell you how serious the issue at hand is. The priorities are called by their letter code and are: V Verbose D Debug I Info W Warning E Error F Fatal S Silent (suppress all output) These are in ascending order. In other words, Verbose or V is going to be the micro information which doesn't really mean much to anyone 99.99% of the time where as Fatal or F is going to be a huge catastrophic issue. When filtering for a Priority it will include the Priority you give PLUS all HIGHER Priorities. So, for example, if you call to filter for Warning or W then it will give you Warning, Error, and Fatal. That is common to filter for. Below are some examples of code: ( PS - you would never actually type or input ‘{‘ or ‘}’ in your logcat commands .. they are in some of the examples below to show you that these are generic modifiers … meaning - if you were actually inputting the command you would replace the {Tag} with an actual Tag, like: ActivityManager or GTalkService .. in the same way you would replace {Priority} with an actual Priority, such as: W or E ) Examples Code: adb logcat {Tag}:{Priority} *:S > ~/Desktop/logcat.txt
adb logcat {Tag}:{Priority} *:S > %userprofile%\desktop\logcat.txt The above line is if you know exactly what Tag (GTalkService or ActivityManager) and Priority (W or E) you are looking for. Code: adb logcat *:{Priority} *:S > ~/Desktop/logcat.txt
adb logcat *:{Priority} *:S > %userprofile%\desktop\logcat.txt The above line is if you don't know the Tag, but know the Priority. The * is a wild card that basically means all/any. An example of a VERY valuable logcat could be: Code: adb logcat *:W *:S > ~/Desktop/logcatALLwarnings.txt
adb logcat *:W *:S > %userprofile%\desktop\logcat.txt So, the command above would give you all tags that had a priority of Warning, Error, or Fatal. It would silence (not show) everything else and would pipe the output of your log to your desktop as a text file named logcatALLwarnings.txt … moving along … Code: adb logcat {Tag}:V *:S > ~/Desktop/logcat.txt
adb logcat {Tag}:V *:S > %userprofile%\desktop\logcat.txt The above line is if you know the Tag but want to see all Priorities. {Tag}:V outputs all priorities for the specific Tag you’ve entered because it calls for the V (Verbose) priority, which is the very lowest priority … and as you recall, it always gives you the priority you’ve asked for AND above. The *:S tells the logcat to Silence (or ignore) all lines/messages that have not otherwise been specifically called for using these filter expressions. This CAN cause issues though, sometimes it will silence what you're looking for / everything. A final specific example from my phone to be clear. I got a Database Tag with an Info Priority, if I wanted to see all instances of this happening, I could use the following code: Code: adb logcat Database:I *:S > ~/Desktop/logcat.txt
adb logcat Database:I *:S > %userprofile%\desktop\logcat.txt Or, if I had an ActivityManager Warning I could use Code: adb logcat ActivityManager:W *:S > ~/Desktop/logcat.txt
adb logcat ActivityManager:W *:S > %userprofile%\desktop\logcat.txt Ok, now we're going to the show! You know the tools, but how do I use them? Glad you asked! For the first time you boot a ROM/Kernel bundled together (IE InsomMIUI 1.12.2) or for just a kernel you're going to do the following: Once you're finished full wiping and installing the ROM, but haven't rebooted the phone yet. (Or wiping just the caches for a separate Kernel): - Open Terminal on your computer
- enter the following code
adb logcat -v long > %userprofile%\desktop\logcat.txt [INDENT=2] [/INDENT] - Name the logcat something useful. A good format is to use you're initials, rom name, what it is, and date. This way it stands out. So the code with the really long but helpful file name would be:
Code: adb logcat -v long > ~/Desktop/JH_InsomMIUI1122_firstboot_5Dect11.txt
adb logcat -v long > %userprofile%\desktop\JH_InsomMIUI1122_firstboot_5Dect11.txt - Yes, I know that's a long name, but we look at dozens of these things, it helps!
- In recovery tell it to reboot the phone. The logcat will start recording internally on your device at boot automatically.
- Once the phone is at the lockscreen let it sit for 5 minutes.
- Unlock the phone and let it sit for about 10 seconds.
- Restart the phone.
- Once you restart the phone open the logcat file on your desktop to make sure it’s not blank/empty/something went wrong and if everything’s golden - send to your favorite developer (ME!
- FYI , the -v option sets the output format. -v long after the logcat command formats the log so that it adds a date and time stamp to each line. It also separates each line with a blank line .. making the log as a whole much easier to look through.
- That's it, you should be off to the races with these logcats. I hope this has helped!
Thanked by 12 auburngirl,
dboftlp,
Epiksol,
jmuru,
jschreff,
Lttlwing16,
NotJustAPhone,
Paul627g,
ragnarokx,
rwong48,
tropper,
Whyzor |
