Results 1 to 3 of 3
    Default trouble with recovery mode on lg optimus s
    I was wondering if anybody knew of a fix or have had this problem. I rooted my duaghter's lg optimus s last night and installed rom manager to flash clockwork mod recovery and cyanogen mod. I watched a you tube video that showed someone doing this successfully. It wasnt until after the fact that I saw the warning about using rom manager with the optimus s. Now her phone has no service, 3g, or wifi capability. I can go to recovery mode, but whenever I make a selection all I get is the rom manager symbol. The only way to get rid of this is to take the battery out. Does anybody know how to fix this problem?
  2. #2
    Moscow Desire's Avatar
    Troubleshooter
    Posts
    ROM
    Jiffy Pop Roots 3.47.114
    Default Re: trouble with recovery mode on lg optimus s
    Here you go.
    Instructions near the bottom of the post. This should reflash the correct recovery for your device.
    [Custom Recovery] Xionia Clockwork (CWMA v1.2518.6)
    Thanks. I finally got it to go into recovery mode and was able to reflash the stock ROM. Will definitely delete the rom manger and install the new recovery.
