Results 1 to 11 of 11
    junipertodd's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Default How to hookup to a computer via USB
    Hello: I'm a new Incredible user and I'm having problems hooking up my phone to my computer via USB. When I do, I only can access the phone's internal storage, not my SD card. I've confirmed that it's "mounted" in the phone but it does not appear as a drive in Windows Explorer. Help!
  2. #2
    prometheus's Avatar
    Posts
    Global Posts
    2,205 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by junipertodd View Post
    I have a Moto Droid. So, I don't know if it's the same. But, I had the same problem and here's how I fixed it. Try this:
    Home screen >> menu >> settings >> applications >> development >> now, under the top selection, "USB Debugging" - make sure that is NOT checked.
    If the Inc menus are different or you're on a different OS just try looking ofr USB debugging mode somewhere and mess with that setting. Good luck.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Default
    thanks for the tip, but it didn't work. I have selection but it wasn't already checked. For grins, I checked it and reattached the cable to try again. Still the same result... only one drive.
  4. #4
    prometheus's Avatar
    Posts
    Global Posts
    2,205 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    curses, foiled again.
  5. #5
    Kyle Gibb's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Do you have any other way to read a SD card? You should have gotten a SD card adapter with your microSD card so if you have a printer or something you could try to access the card from that.
    And I have debugging on, try using that?
  6. #6
    andrewkevin's Avatar
    Posts
    Global Posts
    2 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Hi,
    Recently i have bought a new phone and i want some files to be transferred from my pc to my phone, but when i plug my cable, my pc is not at all recognizing. I need help.
    Thanks and regards
    Portable hard drive
  7. #7
    Foxman's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Ok, so this might sound pretty obvious, but do you have the latest HTC Sync installed? That has the necessary USB drivers for HTC phones.
  8. Thread Author  Thread Author    #8
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Talking
    Hey, I bet that's it. I'll check about the HTC Sync driver on my office computer. Thanks for the tip!
  9. #9
    Foxman's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    No problem, I hope it works! Just holler if you have any trouble, there are many good people here to help.
  10. Thread Author  Thread Author    #10
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Default
    Yep, installing HTC Sync did the trick. Thanks for the tip!
  11. #11
    nasalpancho's Avatar
    Posts
    Global Posts
    86 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I cant find my X's SD card on my pc -- can anyone help?
