Results 1 to 3 of 3
    icedcoffee10702's Avatar
    Posts
    ROM
    Cyanogenmod mod 9
    Default Restore/backup help
    Ok so i have cyanogen mod 7 and would like to go back to stock android. I have all the apps on the phone I want on my phone.I don't want to have to go back and find them in the market when I restore my phone which wipes my whole phone as far as i can tell because i can't remove the sd card from my phone because its a nexus s 4g. I have all my apps backed up titanium and app backup and restore from the market to my sd card. So I guess my question is how to you backup apps when your doing a full restore if that makes since...
  2. #2
    Default
    Just pull the directory generated by Titanium to a desktop PC. Then after the wipe replace it and restore using titanium.
  3. #3
    Moscow Desire's Avatar
    Troubleshooter
    Posts
    ROM
    Jiffy Pop Roots 3.47.114
    Default Re: Restore/backup help
    Quote Originally Posted by Originalme8 View Post
    Just make sure you only backed up downloaded apps, and NOT system apps and data or else you'll have a mess on your hands.
