I posted this over at xda, but in the hopes of saving other Netgear Readyshare users some time
For anyone still trying to achieve netgear usb_storage readyshare access on their android device:
I am using ES File Explorer to access my hard drive (1.5TB) on my Wifi network (NetgearWNDR3400) using the FTP tab in ES File Explorer.
Login to the router 192 . 168 . 1 . 1 (for this model) on your pc or phone browser and enable the ftp access method under the usb storage advanced settings. Ive kept all-access no password for the time being.
In ES File Explorer you will add a new ftp server using 192 . 168 . 0 . 3/shares as the ftp server. check the anonymous box and make sure you are using port 21 then tap ok.
Your shared drive should now appear as "shares@ 192 . 168 . 0 . 3" in the FTP Servers window.
I was also able to see my shares using my phone browser (dolphin) by using http: / / readyshare . routerlogin . net / shares in the url, but this not as usefule as using ES File Explorer cut and paste files and folders.
Before getting this new router, I was sharing the drive over my network by using my Windows desktop as a server. The best part of this was that ES File Explorer would easily scan and find the server in the LAN Shares. The problem with this setup was that the desktop had to be on whenever I wanted access to my external drive over wifi and (because of DHCP on the router) the IP address was not exactly the same everyday because of multiple devices on the network.
All this can be done in Astro as well, but you'll need to download the smb module.
Sorry about the spaces in the urls. The forum would not let me post the "links" because of spam rules.
By the way, forgot to mention
the LAN Shares doesn't work because the HDD is formatted in FAT32 for Windows OS use. You would have to reformat your drive in ext3 for Linux use in order access it from your android device. Not a solution when you have hundreds of gigs of data on it already.
