SKIKER IS MY HERO! If you have a
Samsung Stratosphere,
this definitely works!! It just saved my phone. I didn't have to do a factory reset and lose all of my settings (like the Verizon Customer Service recommended) because of the help of this forum. If you follow the instructions Skiker listed above, you will be able to change the settings back that the "Easy Battery Saver" app screwed up. The Verizon Customer Service representative admitted he didn't know how to do this. Thanks again for your help! I've been dealing with wifi ONLY for the last 2 weeks. I'm so glad I get to use the 3G and 4G now!
One thing I would add to the instructions for a bit more thoroughness is that when you go into the Any Cut app, which you downloaded from the market, and you select "New shortcut", you then need to select, "Activity" in order to find the APNs. Select APNs to create a shortcut. [Indeed, it did create the shortcut to my 3rd page of my home screen since my 1st two were full.]
