- 01-05-2012, 03:29 PM #26
- 01-06-2012, 03:26 PM #27
- 01-06-2012, 03:43 PM #28
Re: HOW-TO Compile ICS AOSP (XOOM/GNEX/NEXUS S)
Jerry- First of all, this guide is really phenomenal. No joke. You really have a true knack for walking a beginner's mind through a seemingly chaotic procedure, and making it less intimidating by speaking direct, and on-level with the reader.(as opposed to some Internet tutorials, where an author is clearly writing in a format that serves their own ego, and couldn't care less how it might translate to someone a bit less savvy.)........ So thanks for the careful work and dedication you put in this.
To get to my point...I actually have a question.(this might shock those who know me around here, or from XDA, due to the fact that I have never really, formally asked for help, lol.)
I have successfully compiled ICS for the Crespo4g, and it built correctly, I believe.. however, I have a couple nagging "issues". The first and most important question I have is: The ota package that I built is very much like a CyanogenMod ota-flashable, in that it has included only the core OS/kernel.. Theres no Gapps of any kind, not even the market. Now, this isn't shocking to me, as I'm obviously familiar with the agreement between Google and CyanogenMod. What confuses me, is there doesn't appear to be an instruction set anywhere that explains how to compile a Gapps package separately,or how to compile and merge the official apks with the base OS package. I tried flashing the newest Gapps, however the market fails every time I attempt to update any google app, as well as most non-google apps too. If I had to guess, I'd assume that it's because the signatures are different between the Gapps and my personally signed build, therefore causing conflict. If thats the case..then we're brought back to my main question: Where do I get official google apks to merge into my build, and how can I do it?
Second question is small
...My core build has everything working flawlessly within it, except for one stupid thing. The keyboard. Its spelling correction/suggestion setting does not work, no matter what. Everything is underlined in red, as if it were misspelled. I remember this being an issue around the time Kwiboo/Koush started pumping out their early, unofficial builds of ICS,and I think it was resolved pretty quickly. You have a Nexus S Jerry, and you ran the early ICS builds; Do you have any insight on this possibly being an error in my compiling, or do you think this is a native issue residing within the ICS source code? If anyone else has built AOSP ICS, and has had this problem, but fixed it, please give me a shout-out on how you achieved thats.
And those are my two gigantic questions....Any insight offered would be immensely appreciated! Thanks for reading my book!
- 01-07-2012, 12:58 PM #29
Not to discourage you from trying but if all else fails... http://forums.androidcentral.com/spr...d-01-02-a.html
- 01-08-2012, 08:43 AM #30
Not quite what I'm looking for, lol; but nonetheless I appreciate the link, as I'm not one to turn down a good Beezy rom
Seriously though, that's not discouraging at all. In fact, I'm very patiently working on this, and I'm just thankful that I even completed the core package with total success. Every time I get something right, it makes me wanna learn to do more&more. Now, I just need to learn how to tie it all up into a neat little package with all signing/key-usage compatibilities intact
Anyone who is willing to work with me would be appreciated beyond measure. I learn fast, and have other skills to offer.
Thanks! - 01-08-2012, 12:13 PM #31Thanked by:
- 01-13-2012, 10:17 AM #32
- 01-13-2012, 11:56 AM #33
Re: HOW-TO Compile ICS AOSP 4.0.3 (XOOM/GNEX/NEXUS S)
Not sure about the GPS... its working on my build. I'm hoping someone can tell me what I'm missing trying to access su... permission denied! I built full Toro user debug which includes su.. when it didn't work I flashed an su.zip which replaced the su and installs superuser.apk. bellow is the log at of when I attempt to access su:
E/su (17526): sudb - Opening database
E/su (17526): sudb - Database opened
E/su (17526): sudb - Database closed
V/alogcat (17464): resumed
I/ActivityThread(17551): Pub com.google.android.calendar.CalendarRecentSuggestionsProvider: com.android.calendar.CalendarRecentSuggestionsProvider
I/ActivityManager( 179): No longer want com.noshufou.android.su (pid 16895): hidden #16
E/su (17526): select failed with 2: No such file or directory
W/su (17526): request rejected (10073->0 /system/bin/sh)
I'm running an insecured
boot.img that I made from my compiled img which I know is working because I can now adb remount. Adb shell also shows I'm @root # or however its printed.. any help would be appreciated!Android, not only an OS.... Its an Obsession! - 01-13-2012, 01:00 PM #34
I'm still very new to building, however, I might be able to point you in the right direction. I have successfully contacted a couple extremely generous developers lately, in hopes of learning more about the post-compiling process, and I've learned a bit more.
In regards to your question: One thing I have learned more about, is the central importance of editing the build.prop file. Since I was compiling for a targeted build device, (the crespo4g) I was under the naive assumption that the build.prop would generated with everything I needed. I was wrong..
My suggestion for you, would be to download a fully working custom build of the most recent Toro release, if you don't have one available already. Open it up, and get the build.prop file from it..
Now, open your ROM in it's current state ,and get the build.prop from it as well. Have both build.props open side-by-side on your screen. I suggest you carefully study every difference between yours and the one from the known-working build. Think about each difference you find very carefully, and come to a conclusion about the reason for it.(ex. The date on the build.props is different..you can safely rule that out as something that needs changing, as it has no bearing on the functionality of your features
) The place where you're likely to find critical differences (if any) is towards the bottom of the build.prop. Are there any Google Maps permission lines written on it, that you don't have included on yours? Are there any "google-service" related permission lines on yours at all?
Start there- with the build.prop comparison, paying special attention to any lines that give permissions for a service. This task will likely reveal something of significance to you, and even if it doesn't- it will help rule out that possibility, and you can move onto another.
I hope this something I've said makes sense.
lol. Post a reply on how that goes, if you think of it. It could help another reader.. Good luck! (seriously....s**t ain't easy, lol)
- 01-13-2012, 02:02 PM #35
- 01-14-2012, 01:38 PM #36
Is there a guide that shows how to add ChainsDD SU to the source so it will build with aosp?
- 01-14-2012, 07:09 PM #37
I've tried to compare build.prop-files. (The original from stock 4.0.2 with the one from my AOSP)
I didn't find anything there that can explain why my gps is dead.
It works just fine in 4.0.2, but not in my aosp..
I've also tried to compile the aosp all over again, with the same result..
- 01-15-2012, 06:48 AM #38
- 01-16-2012, 06:31 AM #39
- 01-28-2012, 01:13 PM #40
I just finished building on my MBP in a VM running Ubuntu 10.04LTS. It took about 45 mins, which I thought was shockingly fast (maybe not since the VM has 4GB of my RAM and a 16GB swap). If you are a Mac user and want to build in MacOS - don't... seriously, save yourself a night and just set up a dual boot or a VM.
I have a question though, I got the build working with a data connection but the camera isn't working. I learned so far that it requires a proprietary driver that isn't open sourced, so what should I be looking for to get that piece working? - 01-28-2012, 01:25 PM #41
- 01-28-2012, 01:33 PM #42
- 02-06-2012, 05:21 AM #43
- 02-07-2012, 11:35 AM #44
The 4.0.4 release is only a leak as of now and I don't believe that Google has ever officially confirmed, nor denied this build's existence. I have been using the 4.0.4 leak on my Nexus S 4G for almost a week, and it does seem ready for release, however.. nobody (except insiders, of course) can speak with much certainty as to what Google's intentions behind this build number are. It could be just one of many test builds that will never see the light of day. The possibilities are endless. One thing I can say for sure though, is that the source has not been made public yet. Whether or not 4.0.4 even pans out, I wouldn't worry about it. Nothing stands out about it, so you're not missing anything noticeable..Just keep building, and good luck
- 02-09-2012, 08:53 AM #45
I have a 4G Xoom and have been wondering why ICS hasn't officially come out yet.
When I read Jerry's excellent instructions, it almost seems too easy and given there is no OEM bloatware... why isn't it out yet if compiling is this easy?
Then I wonder why so many ROMs for the Xoom have one thing or another that still doesn't work. I guess I am confused what benefit there is in waiting on the real build of ICS for the Xoom. I've stayed away from an AOSP build because I don't want half of the tablet's functionality lost and I figure if people smarter than me can't get it 100%... well that's why I've been waiting rather than doing the AOSP thing. But this makes it sound like it'll just work because it's a Google Experience Device.
So I guess I am confused as to what is "lost" if you roll your own. And if the answer is nothing, then why are so many ICS builds for the Xoom hobbled in one way or another?
Ben - 03-07-2012, 01:31 AM #46
- 03-12-2012, 04:14 PM #47
- 03-14-2012, 02:26 PM #48
I am confused too, and would appreciate it if someone could explain this. I can see why rolling your own build has issues with non google experience devices due to the unavailability of binaries for hardware support. But since those are readily available for all google experience devices including XOOM and Nexus S (), what is it that's preventing an AOSP build to work properly?
- 03-20-2012, 11:17 PM #49
Hi,
thanks for the tutorial. I was able to build my first aosp ics ROM with your help. I have one question. I would like to make the kernel insecure. Does the aosp source include the kernel or does it download prebuilt kernels? I just need to know so I can look elsewhere for the kernel source. Couldn't find any source when I searched in the aosp directories.
thanks. - 04-16-2012, 07:58 AM #50
Reply
