Results 1 to 8 of 8
    Default DM initialization not ready check network or sim card
    please help me out in fixing this error " Dm initialization not ready please check network or sim card "
  2. #2
    Default Re: DM initialization not ready check network or sim card
    Hello,
    Welcome to the forum. Is your phone rooted? If so then that is a normal a message as rooted phones can't do ota updates. If you want to clear that message then unroot. However, If your not rooted, then make sure device management is excluded from your task manager then, with the phone on, pop the battery out and then put it back in and then restart the phone. All the best for the New Year.
  3. #3
    I just fixed the problem by disconnecting wifi and then doing the update check. Still no Jellybean...:~(
  4. #4
    I'm sorry to hear that...hopefully you'll find some sort of solutions here on the forum.
    Best of luck.
    Sent from my PG86100 using Xparent Green Tapatalk 2
  5. #5
    i see this was in 2011 but i am having this problem i rooted then returned to stock and now my iemi is lost and i cant figure out how to fix it?
  6. #6
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,664 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Quote Originally Posted by Andrea Charles1 View Post
    Welcome to the forums. Unfortunately, I do not know of a way to restore an IMEI.
  7. #7
    Quote Originally Posted by Golfdriver97 View Post
    Sir...can you help me?...I have samsung note 2 sgh-i317...and i want to upgrade my phone to a higher version...but it said dm initialization not ready check network or sim card...
    What should I do...my phone is rooted...
  8. #8
    Posts
    Global Posts
    32,664 Global Posts
    Carrier
    Quote Originally Posted by hiro kazuya View Post
    You would most likely have to install a custom ROM like Cyanogen.
