Reverse USB Tether for Nook Color
BCable
4
Right now I have tried a lot of options to get my Nook Color running CM7 to get internet access at work (buggy driver on B&N that doesn't work with our EAP settings), and none of my alternatives are good enough.
I was running my own access point from my computer but then the telecom guys told me to turn it off. Tried Bluetooth tether and that just doesn't work very well (it constantly drops connections).
So I want something seemingly very simple, but I can't find anything anywhere on how to do it. I want to plug my Nook into my computer and use that computer's internet connection. I imagine it can't be very difficult using ADB, but I can't find any information about it.
I have Arch Linux and Debian Linux at work.
Thanks.
kyleazle
i think you could use an app called reverse tether, its like 2.00$. i to have a nook color running CM7. im not sure if thats what your looking for, but i hope it helps.:cool:
kerokekerol
