Trouble Rooting Samsung Fascinate
Johnpwhite
I am using the root software suggested. Everything runs fine and then I get to this message (picture). Can anyone tell me what I am doing wrong?
Dadstar
3
I was having the exact same problem and message as you. After I kept trying and failing, i came to a conclusion: no developers use the fascinate anymore, and since the only easy root is for ?clair, this phone is unrootable unless you can find a way to downgrade the phone to 2.1 (A factory reset does not downgrade it. I learned that the hard way.)
Nanran21
