1. dimsdale's Avatar
    I'm running AdFree on my Samsung Galaxy Nexus. 4.0.2, unlocked, rooted, otherwise stock.
    I noticed that AdFree doesn't block ads on Angry Birds? Has anyone else noticed that, or is there a configuration problem on my end?
    AdFree is blocking ads in GasBuddy and TweetCaster, so I know it basically works. It even blocks ads in Words with Friends (App displays a blank black ad screen with return to game button, but with no content).
    Is there something I can do to make it work with Angry Birds?
    01-20-2012 12:16 PM
  2. moosc's Avatar
    I've noticed its hit and miss with ics and adfree
    Sent from my Galaxy Nexus using Xparent Cyan Tapatalk
    01-20-2012 12:35 PM
  3. dimsdale's Avatar
    Is that to suggest that adfree is successfully removing the ads from angry birds on your bionic?
    01-20-2012 01:15 PM
  4. pazzo02's Avatar
    I'm running Android Revolution ROM, and I've noticed intermittent ad blocking in all the Angry Birds apps. Maybe a future update to Adfree will fix this.
    01-20-2012 01:44 PM
  5. moosc's Avatar
    Not sure haven't used bionic since Nov. I'm running darkside asop on my g nexus
    01-20-2012 06:32 PM
  6. srkmagnus's Avatar
    By disabling mobile network or enabling Airplane Mode (There both the same thing basically) you'll not see the ads. The downside is that you won't see any incoming messages, receive calls, etc.
    01-20-2012 06:52 PM
  7. PeterRedBird's Avatar
    just disable the wifi and the 3g features and you'll be ok...
    01-08-2013 05:49 AM
  8. ignb's Avatar
    I see annoying ads on my PC and Android seems to be no different However, I don't use any of these ad blocking apps. I simply disable my wifi.
    01-08-2013 12:29 PM
  9. chadthebuilder's Avatar
    I simply cannot use ad-block on my tablet for the reason that it always signs me out of my online sites that I am logged into. This gets very annoying. If I am not using an online service, I do exactly what the above user does.
    01-09-2013 07:22 PM
  10. ignb's Avatar
    Agree. I mean some of the ads are really annoying and sometimes even misleading but since it's only an ad I don't really care. Except those 'you phone is infected' ads, they should be blocked for sure.
    01-22-2014 09:01 AM
