1. petya0980's Avatar
    Ok so my question is , If i buy the Droid Razr Maxx and unlock it , there's many tutorials , but if i unlock it can i use the 4g sim-card slot for other carriers in another country , not Verizon in that country but different carrier. And no i dont want 4g in that country they dont support it anyways. Also if it does can anyone help me find if they support the company Kyivstar its a Ukrainian company.
    01-27-2012 02:52 AM
  2. pazzo02's Avatar
    I'm not positive, but I would say no. It is a CDMA phone, and most of the world is GSM.
    01-27-2012 09:37 AM
  3. petya0980's Avatar
    yes but it does have a sim card slot so y not?
    01-27-2012 03:26 PM
  4. fatboy97's Avatar
    Ya, it has a SIM card slot... but that still will not help it get the hardware required to run on a GSM network in some other country.
    01-27-2012 05:35 PM
  5. pazzo02's Avatar
    The sim card will not change it from a CDMA to a GSM phone, that is built into the hardware.
    01-27-2012 05:53 PM
