Results 1 to 7 of 7
- 01-27-2012, 12:14 PM
Thread Author #1
Converting dvd to ??? For motorola xoom wifi
What is the best way or freeware to convert dvd's to a compatible format to play on Motorola Xoom wifi?
- 01-27-2012, 07:10 PM #2
- 01-27-2012, 11:46 PM #3
- 01-28-2012, 11:06 AM #4
Re: Converting dvd to ??? For motorola xoom wifi
I use DVD Catalyst. It's not free, but for $10, it was worth it because it's pretty much no-brainer. I'm not even slightly technical - I'm sure Handbrake is easy but I couldn't figure it out even using the guide. I'm a hopelessly perpetual noob. I like DVD Catalyst because it has the presets for your device and then you can tweak as you like if you understand what you're doing. The $10 is lifetime.
- 02-27-2012, 01:58 AM #5
you may want leawo dvd ripper, which converter dvd to various format you want. it is effective and cheap,you can have a try.
- 01-21-2013, 04:50 AM #6If you want to know something about flash player go to this blog flash-video-player.blogspot.com
- 01-21-2013, 10:12 AM #7
Handbrake works great for me and my Xoom. You should try Handbrake first, since it is free, and see what you think.
Reply
