Problem:
I renamed a zip file in my sd card and a warning popped up. I pressed on the button and my phone turned off. I turned it back on and my phone was stuck in an endless boot loop. I took out the battery and the same thing happened.
Solution:
I went to the recovery screen and wiped everything. I rebooted my phone. My custom boot was replaced by the stock boot (haven't seen this in forever). After waiting and praying for five minutes, the setup wizard screen appeared.
Don't rename zip files in your sd card or this could happen.
Solution:
