1. puchdog's Avatar
    How to you add custom ringtone to the evo?
    06-04-2010 06:24 PM
  2. allsighs's Avatar
    I connected mine to my computer via USB (USB drive mode). I created a folder called ringtones and added a bunch of custom MP3 ringtones i had made for my Pre. After disconnecting the cable they all showed up in my list of ringtones
    06-04-2010 11:40 PM
  3. broli's Avatar
    i use ring extended
    search the market
    06-05-2010 01:41 PM
