Results 1 to 5 of 5
- 02-15-2012, 10:17 AM
Thread Author #1
help!
So ive given up on rooting my zte score cuz on rockthatmobile the instructions are for windows 7 i have xp, but anyways how can i download a app n then store in a service like dropbox so it doesnt use up my internal memory. I wish i could root my zte score but its stays stuck in something daemon.
- 02-15-2012, 10:26 AM #2
Re: help!
Unfortunately you can't install an app to an outside source like Dropbox, etc...
All you have is internal system allocated memory for apps or if your lucky it can be installed then transfered to SDCARD to help save some space.
:: Getting Started with Android :: Forum Rules :: General Help and How To ::
» » » The All New Android Central App « « «
- 02-15-2012, 11:46 AM #3
Re: help!
I suggest that you offer a more informative title than “Help!”
- 02-18-2012, 10:23 PM #4
- 02-19-2012, 10:13 PM #5
Reply
