How to Set Wallpaper without cropping?
I found some pretty neat wallpapers, 480x800 I believe, and would like to use them on my EVO. Looking at them in the Gallery they are damn sweet, BUT when I try to set them as Wallpaper a cropping tool pops up.
I want to use the images as they are seen in the gallery, cropping doesn't cover the entire image and looks like day old death. Am I asking for something that's impossible?
Re: How to Set Wallpaper without cropping?
Unfortunately, Android can't stretch the wallpaper, or fill in the missing space, so the only solution is to edit the picture on your desktop machine to the correct size and aspect ratio (<removed>). That, or you must crop. Sorry! :(
edit: I got the resolution so very wrong, sorry! Please see my post below for the correct wallpaper size!
Well what you could do is go to google images on your phone, find your wallpaper, click on it, and then on the top right corner there should be see full size image. Click on it and then touch and hold the picture in full size image and there should be a pop up the just click set as wallpaper. Hope it work, it does with my phone
the resolution of the picture should match the resolution of the screen at least
then there would be less cropping.
do what i am doing.
just download any app from play store like "personal wallpapers" or any other like that and set your wallpaper without cropping and it can change your selected wall paper automatically also.
i hope u like it.:);)
