Results 1 to 11 of 11
    ColdSpike's Avatar
    Posts
    Global Posts
    41 Global Posts
    Default How to Set Wallpaper without cropping?
    I found some pretty neat wallpapers, 480x800 I believe, and would like to use them on my EVO. Looking at them in the Gallery they are damn sweet, BUT when I try to set them as Wallpaper a cropping tool pops up.
    I want to use the images as they are seen in the gallery, cropping doesn't cover the entire image and looks like day old death. Am I asking for something that's impossible?
  2. #2
    Default Re: How to Set Wallpaper without cropping?
    Unfortunately, Android can't stretch the wallpaper, or fill in the missing space, so the only solution is to edit the picture on your desktop machine to the correct size and aspect ratio (<removed>). That, or you must crop. Sorry!
    edit: I got the resolution so very wrong, sorry! Please see my post below for the correct wallpaper size!
    White GSM HTC Hero, stock ROM
    Tweet me @BrokenFox
    Thanked by:
    ColdSpike's Avatar
    Posts
    Global Posts
    41 Global Posts
    Default
    Thanks for the reply! I was mistaken in my OP, the wallpapers that I downloaded were 480x800, just checked them.
    What is the size I would need for Android to use without distorting the image? I thought that if I got images the same size as the screen resolution I would be good. What I don't understand is, the cropping tool pops up, I make the area to be cropped as large as I can but when it is displayed on the screen its been horribly blown up.
  4. #4
    Default
    I'm so sorry, I was mistaken! The different resolution got me confused, I'm used to my 320x480 Hero. The EVO's screen is 480x800, but the wallpaper should be bigger, as with every Android phone. When you scroll the home screen, it moves over the wallpaper left and right, so at any time, it only shows a portion of it. You should look for wallpapers the same height as your screen, but twice the width! That's 960x800, or anything larger since you can then crop without losing quality. Sorry again, for confusing you!
    Tweet me @BrokenFox
  5. #5
    Cowchip's Avatar
    Posts
    Global Posts
    546 Global Posts
    Default
    What I don't understand is that even though I download the correct wallpaper size, I still have to use the cropping tool. Not a big deal, but why use 960x800 if it has to be cropped anyway?
  6. #6
    Default
    If the image is the correct aspect ratio, the cropping tool will cover the whole of it. Why the need then? Don't know! It's something we must live with, I guess.
    Tweet me @BrokenFox
  7. #7
    lcsglvr's Avatar
    Posts
    ROM
    stock
    Default
    Get flickie wallpapers. Within that program, you can select a custom wallpaper and don't have to crop.
  8. #8
    Default
    Go to the android market and search for "Wallpaper set and save" its free and you set the wallpaper and avoid having to crop your picture.
    Enjoy
  9. #9
    Default
    Quote Originally Posted by ditchparrot View Post
    If you have to crop you got the aspect ratio wrong so the resolution you're using isn't correct.
    Whatever's left outside the crop box is your clue as to which dimension is off.
  10. #10
    Well what you could do is go to google images on your phone, find your wallpaper, click on it, and then on the top right corner there should be see full size image. Click on it and then touch and hold the picture in full size image and there should be a pop up the just click set as wallpaper. Hope it work, it does with my phone
  11. #11
    the resolution of the picture should match the resolution of the screen at least
    then there would be less cropping.
