1. llanita's Avatar
    I've done a search and haven't come up with any solution in any of them. Noone posts in the LG Enlighten forum, and I need help because I've been getting message that I'm almost full. So I would like to move my photos to the sd card. Thanks
    02-17-2012 10:49 AM
  2. Meiji's Avatar
    Hi! Just open any File Manager, create a photos folder in your external sd card and copy them there.
    02-17-2012 01:34 PM
  3. pazzo02's Avatar
    I thought most phones saved pictures to the SD card by default. I guess not the Enlighten.
    A few things to check. Make sure it's not talking about the SD card that's getting low on space. I see that it only comes with a 2gb SD card. And if indeed the photos are not on the SD card, check the phone app and see if it has a setting for where you want the photos saved. Also, as Meiji said, grab a file manager app from the Market. You'll probably use it for more than just this problem.
    02-17-2012 01:53 PM
  4. llanita's Avatar
    Thanks very much. When I open the file manager (I downloaded ES File Explorer) and I open my pix folder, it shows them in /sdcard/my_pix, but when I view them in Gallery, it only shows 2 photos in my sd card, the rest are Camera with 27 photos, download has 5, and my_pix has 72.
    02-24-2012 04:30 PM
  5. pazzo02's Avatar
    If you continue to seach with the file explorer, you'll probably find that those other pictures are on you SD card also, just in another folder.
    As far as your original problem, are you still getting the almost full message? And if so, try to determine exactly what it's referring to. If you want, post the exact wording of the message on here.
    02-24-2012 08:07 PM
