Dialing extensions & Pause character symbol in android contacts
I just realized the lack of this feature (or incompatibility) when I tried to call someone and kept getting "your call cannot be completed" message from Verizon.
If Google is trying to target business users they need to get their act straight. The problem is not putting semi column or comma or upside down questionmark to dial extensions, but the issue is the compatibility.
Outlook and most contact management/e-mail systems use X as a divider between main number and extension.
It also makes sense "x" "eXtension". Anyway, I was able to sync all my contact beautifully, only to find out that I cannot call my clients, friends or the companies where I have to dial extensions. I don't remember all their extensions, and I cannot change hundreds of them one by one.
If anyone figured out a way to fix this, or a way to replace the default "x" for extension in Outlook 2010, please share. Otherwise Android is useless for those calls.
Re: Dialing extensions & Pause character symbol in android contacts
Hi:
I think I am looking for the same thing hyde49314 is but let me put it this way:
When I had a blackberry and anyone sent me an invite to a conference call I could click on the "+15038898499x730199#" and the call would be made to the base number, a pause would be made where the x is and the extension would subsequently be entered. Bam, 1 click dialing. Also "+15038898499,,,730199#" would do the same thing. Even "+15038898499ext.730199#" worked.
My droid doesn't do this. In my E-mail, "+15038898499x730199#" appears to be a clickable link but actually it's two links. I can click on either the number or the extension. This leaves me entering a number, calling it, trying to switch back to the E-mail to memorize a 10 digit extension, and switch back to the call in progress and enter that extension perfectly the first time from memory after having just seen the number for the first time a few minutes ago, all in time before the call times out. Copy and pasting aren't working either, not that they'd be much faster. I've even literally copied the phone and pasted it in a temp doc, gone back, copied the extension, pasted it in a temp doc, then copied that into the phone for dialing. Tedious! Impractical! The bottom line is when you see "+15038898499x730199#" (or something like it) in an E-mail it should provide one click dialing. If not natively then there should be an app for that. Please help this 8year recovering blackberry user love his new Samsung S III.
See if there is any app that allows you to send numbers. In older windows phones (5 or even 6 had it) you could copy the number and then there was a command "send numbers" and when you used the command it would just dial it. (You would dial the phone number, and then "send" the extension) When I used Galaxy Nexus back in february, there was no such application available. I have been back to my Blackberry long time ago, so I have no idea what developments there have been, but seeing your message makes me think there were no updates, or useful apps developed.
Honestly I was thinking OS6/iphone5 was going to fix everything and be the true business phone that could replace BB, but it is a disappointment so far. And on the android side, the only company trying to do something (3rd party apps, interfaces, etc..) is samsung. So since samsung did not do much else for business users, I would think you are going to be out of luck, and you will have to go back and forth dialing. You will probably have to write it down somewhere and then dial.. so much for the latest technology. Or if you get really frustrated, you can just wait for BB10 to see if it helps solve your problems. With the lack of proper e-mail client (that works with exchange server) and the problems with dialing and contact management, I could not stay with android much longer, but S3 is really a sweet device.
I have pretty much the opposite problem. I've used text "extensions" in lots of my Outlook contacts to describe the type of phone number it is. Things like "Summer Home" or "Mary's Cell". Now Android wants to dial the numeric equivalent of these extensions. Is there any way to turn off extension dialing? Is there any special character that implies that everything that follows is a comment?
Thanks,
-barry
still no real answer to this problem? I can't believe it. I m using Calendar Dial which is the only app I ve found that solve a piece of the puzzle but when the conference call numbers are in the body of the invite it still is not smart enough to recognize them and dial the full number. This is incredible to me that BB could figure this out and Andriod can't! This is a small gold mine if someone will put up an app that will handle both situations.
I found an app to solve this - it works - it is called "Dial My Meetings" this one actually pulls the phone numbers from the body of the invite which Calendar Dialer doesn't do - so I ve tried this one now and it works well. Developer is very responsive as well.
I am late to this thread, but for you MS Exchange power users, I highly recommend the paid app Touchdown to handle this extension issue, with a setting "Normalize Contacts". When it syncs your contacts from Exchange (and then to your phone), it will automatically replace in the "ext", or "x", or "X" in the phone with a ";" to pause dialing. This only adjusts this in the phone, not in Outlook.
Also useful with this App...syncing notes, tasks, calendar, allowing modification of Out of Office message, searching on the Exchange server for emails, etc. Much better than the default Android mail app.
Does this app Touchdown work with Lotus Notes?
The next problem, multiple contacts at the same number with different extensions will will not display the correct contact name when dialing.
Sorry, late to the game on this. But if this were me I'd export my contacts from Outlook into Excel and then do a find & replace in the row containing the x. Replace x with , or ,,,
I was thinking a single comma is 1/2 second or 1 second pause... But I also know that some phones have their own way to handle pauses or waits. So consult your phone documentation for best results.
After you have completed editing then I believe you could just import those back to where you need them.
