Android Forums at AndroidCentral.com >  Android Chat >  General Help and How To > Coding Help
Coding Help
    Thread Author   #1
Old 02-22-2012, 03:27 PM
Activity: 0/20
My program has no errors and will not compile. Can anybody help???
Manifest
Code:
<?xml version="1.0" encoding="utf-8"?>
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
    package="your.gas.namespace"
    android:versionCode="1"
    android:versionName="1.0" >
    <uses-sdk android:minSdkVersion="7" />
<uses-permission android:name="android.permission.INTERNET" />
 <uses-library android:name="com.google.android.maps" />
<application
        android:icon="@drawable/ic_launcher"
        android:label="@string/app_name" >
        <activity
            android:name=".MapsActivity" >
            <intent-filter >
                <action android:name="android.intent.action.MAIN" />
                <category android:name="android.intent.category.LAUNCHER" />
            </intent-filter>
        </activity>
    </application>
</manifest>
MapActivity
Code:
package your.gas.namespace;
import java.io.*;
import java.util.*;
import com.google.android.maps.GeoPoint;
import com.google.android.maps.MapActivity;
import com.google.android.maps.MapController;
import com.google.android.maps.MapView;
import com.google.android.maps.MapView.LayoutParams;
import android.location.*;
import android.os.*;
import android.view.*;
import android.widget.*;
import android.content.Context;
import android.content.res.Resources;
import android.graphics.*;
public class MapsActivity extends MapActivity
    MapView mapView;
    MapController mc;
    GeoPoint p;
    class MapOverlay extends com.google.android.maps.Overlay
        @Override
        public boolean draw(Canvas canvas, MapView mapView,
        boolean shadow, long when)
            super.draw(canvas, mapView, shadow);
            //---translate the GeoPoint to screen pixels---
            Point screenPts = new Point();
            mapView.getProjection().toPixels(p, screenPts);
            //---add the marker---
            Bitmap bmp = BitmapFactory.decodeResource(
                getResources(), R.drawable.ic_launcher);
            canvas.drawBitmap(bmp, screenPts.x, screenPts.y-50, null);
            return true;
    /** Called when the activity is first created. */
    @Override
    public void onCreate(Bundle savedInstanceState)
        super.onCreate(savedInstanceState);
        setContentView(R.layout.main);
        mapView = (MapView) findViewById(R.id.mapView);
        LinearLayout zoomLayout = (LinearLayout)findViewById(R.id.zoom);
        View zoomView = mapView.getZoomControls();
        zoomLayout.addView(zoomView,
            new LinearLayout.LayoutParams(
                LayoutParams.WRAP_CONTENT,
                LayoutParams.WRAP_CONTENT));
        mapView.displayZoomControls(true);
        mc = mapView.getController();
        String coordinates[] = {
        		"32.079867,-81.095504",
            	"32.079952,-81.095848",
            	"32.079331,-81.093501",
            	"32.078901,-81.091718",
            	"32.080643,-81.094379",
            	"32.08055,-81.094302",
            	"32.080455,-81.096143",
            	"32.08057,-81.095271",
            	"32.080811,-81.096724",
            	"32.08122,-81.092358",
            	"32.080792,-81.09637",
            	"32.080098,-81.093557",
            	"32.079734,-81.088033",
            	"32.081077,-81.092056",
            	"32.076211,-81.098446",
            	"32.080632,-81.094282",
            	"32.08095,-81.091417",
            	"32.079999,-81.089091",
            	"32.081199,-81.089381",
            	"32.081407,-81.090391"};
            	double lat = Double.parseDouble(coordinates[0]);
        double lng = Double.parseDouble(coordinates[1]);
        p = new GeoPoint(
            (int) (lat * 1E6),
            (int) (lng * 1E6));
        mc.animateTo(p);
        mc.setZoom(17);
        mapView.invalidate();
    @Override
    protected boolean isRouteDisplayed() {
        // TODO Auto-generated method stub
        return false;
		public boolean onTouchEvent(MotionEvent event, MapView mapView)
            //---when user lifts his finger---
            if (event.getAction() == 1) {
                GeoPoint p = mapView.getProjection().fromPixels(
                    (int) event.getX(),
                    (int) event.getY());
                Geocoder geoCoder = new Geocoder(
                    getBaseContext(), Locale.getDefault());
                try {
                    List<Address> addresses = geoCoder.getFromLocation(
                        p.getLatitudeE6()  / 1E6,
                        p.getLongitudeE6() / 1E6, 1);
                    String add = "";
                    if (addresses.size() > 0)
                        for (int i=0; i<addresses.get(0).getMaxAddressLineIndex();
                             i++)
                           add += addresses.get(0).getAddressLine(i) + "\n";
                    Toast.makeText(getBaseContext(), add, Toast.LENGTH_SHORT).show();
                catch (IOException e) {
                    e.printStackTrace();
                return true;
            else
                return false;
