Results 1 to 2 of 2
    ronald_durst's Avatar
    Posts
    Global Posts
    3 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Rooting evo 4g
    I have been trying to root my damn evo 4g for the last 3 hours. Nothing i do is working including unrevoked and revolutionary. Unrevoked hangs at rebooting or some other garbage. Revo doesnt even start. None of the pages for those methods even have instructions. Theres a file to download and a "good luck trying to figure it out on your own dumbass"! What the hell is going on around here!
  2. #2
    pazzo02's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Sabsa Prime ICS
    Default Re: Rooting evo 4g
    Take a look at this thread:
    READ FIRST! - Rooting, Solutions to Problems, the Answer to Life (Updated:11/29/11) - xda-developers
    The number one cause for having problems rooting any device is not following the directions completely. I can't count how many times I've seen someone post "do I really need to..." for a step. If you read up on everything you can find and follow all the directions, you should be fine.
