1. michaeljc70's Avatar
    If I am rooted and do a backup by booting into Clockwork recovery and do a backup, does that save everything on the internal memory of my phone/tablet?
    I have searched all over and I am not clear if it includes stuff I copy (like music, pictures) or it is just the ROM, apps and app data.
    It seems like you can only backup to the internal memory. What do you do if the backup gets too big to fit on there?
    02-28-2012 12:28 PM
  2. pazzo02's Avatar
    CWM backup only backs up the ROM. It doesn't save anything like contacts, apps, home screen settings, etc. Music and pictures are on your SD card, so they'll always be there. You'll need Titanium Backup to save your apps and data. There are also apps that save your home screen settings, but I'm not familiar with them.
    02-28-2012 04:47 PM
  3. michaeljc70's Avatar
    Okay. Thanks.
    I don't really get the point then. I could just wipe the caches and reload the ROM .ZIP and it would be almost the same thing then. Where is the time savings?
    02-28-2012 05:22 PM
  4. Paul627g's Avatar
    To correct what was said above...
    It does make an exact image of what your device is at that point in time..
    OS/kernel/system/data/settings
    Everything minus your sdcard contents....
    So for example you make a Nandroid Backup (Clockwork Backup) and then flash to a completely different ROM... You can then boot back into CWM wipe everything clean, and then restore your Nandroid Backup you made earlier and it will bring you back to the way your device was at that time you made the backup. So it will bring back the ROM/kernel/data/settings. So if you had text messages sitting there, those will be restored too...
    Hope this helps clear things up.
    FYI, Titanium or My Backup are great for doing individual apps & data restores but it doesn't do an image or backup of the OS/kernel.
    PvilleComp, pazzo02 and srkmagnus like this.
    02-28-2012 05:42 PM
  5. pazzo02's Avatar
    Sorry for the misinformation. The one time I ever had to flash my backup, I didn't have any of my previous settings. I must have made the backup before setting everything up.
    02-29-2012 08:34 AM
  6. srkmagnus's Avatar
    Op, it's recommended that you backup immediately after rooting the device. This will give you a clean pallet to reinstall if you ever need to start fresh.
    And as Paul said, there are apps available to backup individual components to transfer to another ROM or future restore. Remember to keep the device sync'd as well.
    Sent from my SPH-D710 using Tapatalk
    02-29-2012 09:50 PM
