Results 1 to 4 of 4
    ETjumps's Avatar
    Posts
    Global Posts
    99 Global Posts
    Default found easy way to get palm memos to android
    "Note everything", export memos from palm desktop to sd card, then import to note everything, worked great.!!!!!finally
  2. #2
    Default
    thanks! I've been dying without my old notes!
  3. #3
    Default Re: found easy way to get palm memos to android
    Quote Originally Posted by CaptainET View Post
    Hi - I'm new to smart phones, had my Palm Centro for years (obviously!), and I just got a Droid 3.
    Can you explain a bit more step-by-step please on how to get these memos over to the droid 3?
    For example:
    1) What does "Note everything" mean? I've got a zillion memos in my Palm Centro.
    2) What is the "sd card" ... and how do I export the memos from the desktop to it?
    3) "Import to note everything" ... sorry, I know each of the words, but I don't know how to understand the command!
    Thanks dude!
  4. #4
    yodatom10's Avatar
    Posts
    Global Posts
    2,050 Global Posts
    Carrier
    Stock
    Default
    Quote Originally Posted by alexis View Post
    For example:
    Thanks dude!
    Note everything is a app from the android market.
    The SD card is a external storage device on the phone in a card form just like a card on a camera but has been shrunk and is realy tiny. I dont believe the Droid 3 comes with one u can get them at Target or bestbuy.
    Sent from my ADR6400L using Tapatalk
