Results 1 to 4 of 4
- 03-07-2012, 12:13 PM
Thread Author #1
Old Versions .... ???
Is there any site or source on the web that provides downloads of old versions of Android Market apps? This would be for apps that are now updated or no longer available on the Market? I am looking for a site similar to "OldVersion.com" which has some old/classic PC software (but this would be something for android apps instead)?
Thanks if anyone knows of a source or sites.
- 03-07-2012, 08:14 PM #2
Re: Old Versions .... ???
Not that I'm aware of - if you know which app you're looking for you may want to try the developer's page or contact the developer.
I know that some apps, like Wireless Tether, are no longer available in the Market for people on Verizon and AT&T, but you can still download it at their site and install it that way.
Hope this helps.Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig. - 04-26-2012, 03:25 PM
Thread Author #3
CustomShortcut gone?
Thanks for the reply. The app that I am looking for in the above post was a free one called CustomShortcut APK. I now have it on one of my two phones (the other phonehad it but was lost and replaced). I have tried looking for a developer page for this app but no luck as everything seems to point back to android market as the source link for download.
Does anyone know of a way or source for me to get this APK back on my other phone? Is there a way to copy it from one phone to the other? I am assuming that it was removed from the market because it may not be compatible with ICS but I am not running ICS. The application was made by appli.club.
Thanks all. - 04-29-2012, 06:31 AM #4
Reply
