1. anglewing's Avatar
    Heya guys! I'm new to these forums. ^.^
    Anyways, I was thinking of getting a new phone, and I'm not sure whether to get the Galaxy Nexus, S2, or Galaxy Note. Or, should I try waiting for S3? Anyone got any idea when that'll be out?
    Thanks in advance!
    03-15-2012 11:28 PM
  2. fatboy97's Avatar
    Rumors keep flying about when the S3 will come out... just check out the recent Blog post here on AC: Samsung Galaxy S3 is/isn't coming, Part VIII
    If you are waiting for the next big thing, then wait... but be warned that there will be something better the day or two after you buy any phone. Find one you like and go for it.
    03-16-2012 07:29 AM
  3. pazzo02's Avatar
    IMO the best way to find out which phone to get is to play with the ones that are available to you, meaning whatever carrier you're on or plan to be on. Go into the store and get some hands on time. Waiting depends on your situation. Do you need a phone now/soon? If not, and you think you might like what's coming, then wait.
    03-16-2012 08:13 AM
  4. anglewing's Avatar
    Well, I've been putting up with a LG C2500 for the past few years.. which is exactly why I'm trying to find the best choice now. XD
    I would prefer to get a new phone by end of april. If S3 is coming during early May though, I wouldn't mind, would wait for it.
    And I guess Pazzo's suggestion does make sense, I should probably go to the shop and get some hands on experience, and see which I prefer.
    03-16-2012 09:46 AM
  5. jonthedroid's Avatar
    if you're looking for high-quality res DON'T go with Motorola RAZR, I still regret not getting a samsung
    03-17-2012 07:33 AM
  6. grunt0300's Avatar
    What carrier are you with? I'm with AT&T, i have a Vivid, and i couldn't be happier.
    03-17-2012 10:07 AM
  7. Uselessbass's Avatar
    I'm a recent iPhone convert I got a Samsung galaxy s2 skyrocket I couldn't be happyier wish I would have made the switch sooner
    Sent from my skyrocket
    03-17-2012 10:20 AM
  8. anglewing's Avatar
    I live in Singapore, so I would probably be going with Singtel or Starhub as a carrier.
    Note or nexus. That is the question. Hmm..
    03-18-2012 04:19 PM
  9. dancing-bass's Avatar
    I did a brief "hands on" with both the Note and the Gnex (roughly about 5 minutes each). Unless you NEED the extra screen size of the Note I'd recommend the Gnex. The Note was pretty cool, but I can see myself getting tired of having something that large with me at all times. The Gnex is a bit more portable/pocketable and (to me) felt far more comfortable to handle and use.
    03-25-2012 02:03 PM
