Results 1 to 3 of 3
    Default messagecs?????
    Does anyone know what "messagecs is and why does it take up so much space? Is there a way to clear the data on it? Thank you anyone who helps.
  2. #2
    pazzo02's Avatar
    Posts
    ROM
    Sabsa Prime ICS
    Default Re: messagecs?????
    From what I could find, it sounds like it has something to do with the SMS database. Do you have a lot of text messages that you haven't deleted? If not, it's possible that the database is corrupted. I don't know where to go from there, but if I can find out I'll let you know.
    Thanked by:
  3. #3
    Quote Originally Posted by CSmith3VO View Post
    Yes, I also would surely like to know what MessageCS is and how to reduce its mass . . .
    Perhaps does the CS mean Contact Store? (I have less than 150 contacts on my Inspire.)
    hummingbirdhill
    THRiVEn and NOTEd 2
