Results 1 to 5 of 5
- 03-16-2012, 10:15 AM
Thread Author #1
- 03-16-2012, 10:46 AM #2
Re: How to delete a bookmark - Samsung
I'll assume you're using the stock browser. Tap Menu, then bookmarks. That should bring up a screen with thumbnails of all your bookmarks. Long press on the one you want to delete until a menu comes up. One of the choices will be delete bookmark. For cleaning temp files/cache, tap Menu, then More, then Settings. There will be choices for clearing cookies, cache, history, etc.
- 03-16-2012, 12:31 PM
Thread Author #3
- 03-16-2012, 04:57 PM #4
Always glad to help.
- 12-15-2012, 12:27 PM #5
Reply
