Page 2 of 2 FirstFirst 12
Results 26 to 33 of 33
Like Tree3Likes
  1. #26
    mohammza's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: 941 error help
    can you share ... what you did to work fine?
  2. #27
    abhivirtualstudios's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Tried uninstalling the updates for PlayStore and it worked
    Settings >> Application >> Google Play Store >> Uninstall Updates.
    Then it will say "This application will be replaced with factory version"
    Then go ahead and download the app which is having issue.
    NOTE: Make sure you are downloading the app before the playstore itself automatically gets updated to the latest version.
    - - - Updated - - -
    Then go ahead and download the app which is having issue. It will download without issues.
  3. #28
    Shadowce Maleno's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i did clear cashe and data, but i had to remove apps completely before reinstalling it in order to get it working. but thanks, i didnt want to touch anything before i found out what is the problem. app that wasnt working was skype. once more, ty a lot
  4. #29
    karim mostafa's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by dingo277 View Post
    I've been getting a lot of 941 errors in the market place when I try and update apps. Is anyone else having this issue after upgrading to ICS?
  5. #30
    Giovanna Hanauer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: 941 error help- hellllllllllllp
    Eu fiz o que o colega sugeriu , fui no play store , configurações, fui em limpar histórico etc.., e clico e não entra neste tópico.
    Continuo com o erro 941 e tenho uma entrevista às 17 pelo hangout e não consigo atualizar
    pleasse
  6. #31
    atxhellcat's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Did anyone think to go into the Play Store settings and check Content Filtering? Just noticed that myself on my Note 4, and for some reason there was a restriction put on. I told it to allow downloading of all apps again, and poof! Issue gone.
  7. #32
    Gilo Erika's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi
    thanks, i also had the error 940 problem and after clearing the data and cash of the playstore app, it's now fixed.
  8. #33
    SeerWS's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    To anyone who's reading, I just got a Note 5 and I found a solution that I haven't seen posted anywhere. The 941 problem happens (I think) because of syncing your Google accounts from a previous phone. The solution is to go into Settings > Accounts and delete all your Google accounts. Then use the solutions seen in this thread to clear cache/data for Google Play Store, Download Manager, etc. After that, restart your phone. Then re-add the Google account(s) that you deleted. Google Play Services should update just fine after that.
    Ersan Seer
    Futurist
