- 03-28-2012, 05:28 PM
Thread Author #1
- 03-28-2012, 07:15 PM #2
Re: 941 error help
Try clearing cache and data in the Play Store app. Menu -> Settings -> Applications -> All
If that does not work uninstall the Play Store update and try to update again.
Hope this helps.Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig. - 03-29-2012, 08:09 AM #3
Re: 941 error help
"URGENT HELP REQUESTED" - I Cannot Download Updates due to ERROR 941 on Google Play/Android Market.
Attention Forum Admins, Developers, Advanced Users, Android Friends, "Please help me"
Ever since Android Market changed/rebranded to Google Play I get the Error 941 error message as soon as I attempt to update my software on my Sprint Samsung Epic 4G (Gingerbread 2.3.6, Model SPH-D700). I also tried to clear the cache, as suggested above, without any success. So, I would appreciate any help from our Android community. Thank You.
Note: Since my phone is under a new, 2-year contract, I am using stock kernel, and will not mod my phone. Thanks.
Update: (March 29, 2012)
The apps I cannot update are: TeleNav GPS Navigator, Adobe Flash Player 11, and Google Maps. (Error message 941)
The app I can update is: Battery Widget. (Zero errors)Last edited by fred1955; 03-29-2012 at 10:59 AM.
- 03-29-2012, 09:31 AM #4
Re: 941 error help
Last night I was getting the same error code, in addition to others, for the first time since the Market re-branded. Since I was using a CM9 ROM I figured it was the ROM and reverted back to stock for the time being. Hopefully this all gets sorted out.
- 03-29-2012, 10:35 AM #5
Re: 941 error help
If the person who opened the topic can make the tittle more better so it could be noticed more Advanced users or developers. Thanks.
Since yesterday I have been getting error message when updating apps in the Play Store But I didn't wanted to open another topic where we can put our problems into one topic.
Error message is "[app name] could not be download due to an error. (940)" this message first came up when I wanted to update Google maps after seeing the new version from AndroidCentral.
This message also affected Adobe flash player as well so I couldn't update this two apps from the market.
Now this two apps don't show in my apps at the market or when I search them.
Another app called Racing Moto was having the same issue yesterday but today gives me this message
"Your content-filtering level doesn't allow you to download this item" I have triple checked the filtering and its not that.
I wanted to make this description properly of this error message because when I was searching on Google about this message they were also a few people with this problem that were complaining on Google forum.
My Device is HTC Desire HD 2.3.5
Many Thanks. - 03-29-2012, 04:46 PM #6
Re: 941 error help
I was getting the same problem on my Samsung Galaxy S Plus GT I9001 after Android Market changed to Play Store. I very quickly resolved the problem by clearing the cache and data in the Play Store. Go to Settings >Applications> Manage Applications> Downloaded. Scroll down to Google Play Store and select. Clear the cache and the data. Return Home and open the Play Store app or, select Applications and find the Play Store icon. Follow the directions and update the apps with the 941 Error. This fix seems to work very well and is painless.
Thanked by 5: - 03-29-2012, 07:30 PM
Thread Author #7
- 03-29-2012, 07:43 PM #8
Re: 941 error help
Did anyone try to clear cache and data from the Play Store app as Andy and I suggested? None of your posts mention if you tried this or not.
If not, then your first step is to clear cache and data from the Play Store app and if that does not work, uninstall the last update, update your apps, re-install the Play Store update.
Hope this helps.Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig.Thanked by: - 03-29-2012, 08:14 PM
Thread Author #9
- 03-30-2012, 02:21 AM #10
Re: 941 error help
Clear the data too, not just the cache. That aught to fix the problem.
Thanked by 2: - 03-30-2012, 08:09 AM #11
Re: 941 error help
Hey Andy.
Thanks for your quick response. I did everything you suggested with no success. My Google Play Store screen only shows two active buttons: Force Stop and Uninstall updates. I cannot click the Clear Cache or Clear Data buttons because they both are inactive and dimmed out. My Sprint phone is the Samsung Epic 4G with Gingerbread 2.3.6.
My phone has plenty of available storage and memory: 225 MB free and 13 GB external storage available on my SD card.
I also chatted with Sprint yesterday, they prepared a problem ticket for me and suggested I chat with their technical department today.
This is a strange issue since I can easily update other apps such as: Battery Widget with no problem.
Yet, the only three apps I cannot update are: TeleNav GPS, Google Maps, and Adobe Player 11.
P.S. If anyone else in these forums have methods that may help us with this issue, please share at your convenience. Kind Regards.Last edited by fred1955; 03-30-2012 at 08:27 AM.
- 03-30-2012, 09:51 AM #12
Re: 941 error help
Thanks PvilleComp & Andy in Mokum
For your quick responses clearing cache didn't however clearing google play data helped and I can update google maps where I couldn't before.
The only app that I can't update at the moment on my Desire HD is Adobe flash player it gives me a error message " Your order is processing . Your item will be available in a few minutes"
Cant complain though It did soft most of the problem.
Thanks again - 03-30-2012, 10:38 AM #13
- 03-30-2012, 09:08 PM
Thread Author #14
- 03-31-2012, 08:59 AM #15
- 03-31-2012, 09:09 AM #16
- 04-03-2012, 02:10 PM #17
Re: 941 error help
Sorry I haven't had a chance to reply back, the trick with uninstalling updates to the Google play app really worked.
Uninstalled the updates on Google Play store updated Adobe Flash Player and restarted my phone so the market could get updated.
thanks dingo277 for the tip really appreciated
- 05-11-2012, 11:49 AM #18
- 05-18-2012, 10:51 PM #19
- 05-21-2012, 10:30 PM #20
- 05-22-2012, 10:50 AM #21
Re: 941 error help
Yeah that worked for me as well.
Had the "941 Error" Google Play trying to update APPs
Fix was as posted by Adviser but added the "Re-boot":
"Clearing cache and data in the Play Store app. Menu -> Settings -> Applications -> All
If that does not work uninstall the Play Store update, Re-boot and then try to update again"
FIXED!
•» Tip: Never rush to download any APP "Updates", read the feedback for a few days so that you can see if other people are having issues with it and/or changes to permissions or other you may not want! Always use a Back Up APP!
•» Free DropBox! Back up to & Sync your Phone to your Computer Free! Always have your stuff when you need it with @ Dropbox . 2GB Plus account is Free! Plus earn up to 500 Mb's for each referral! Up to 32GB Free! http://db.tt/szmjeyX - 05-23-2012, 01:31 PM #22
- 05-30-2012, 03:59 PM #23
- 06-07-2012, 12:16 AM #24
- 12-14-2012, 01:44 AM #25
Reply
