1. gabe082's Avatar
    I recently upgraded to 16gb from an 8gb but now when i install apps from play store they disappear after an hr or so can anyone tell me why its doin this annoying process?
    04-02-2012 12:48 PM
  2. clodfelterac's Avatar
    make a copy of your sdcard to your pc... name it "mybackup" or whatnot... ok, now take your phone and go into recovery... locate the option and format sdcard (sdcard in phone/phone in recovery menu)... after formatting, leave phone in recovery> unmount/remove sd and copy "mybackup" from your pc back to freshly formatted sd... place sd back into phone and mount if needed... clear cache/delvik... reboot... hope this helps... :-)
    04-07-2012 01:46 AM
