Results 1 to 2 of 2
    Default password Help
    How do I change my "Android Central Password"?
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,715 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Default Re: password Help
    On the top of the forum you'll see several options -- User CP is one of them. A pull down menu should come up if you click on it and you'll have the option to click User Control Panel. From there, you'll see several options on the left hand side. Look towards the bottom and click on email and password to change.
