Results 1 to 2 of 2
    Default Cant recieve MMS messages! Help please!
    Hi everyone! New to the forum and androids! Anyways I have searched and wasn't able to find an answer that helped me fix the problem I'm having!
    Here's my issue; when I try to recieve a picture message it simply says downloading but 90% of the time the message never downloads. Occasionally the message will download the next day. The same goes when trying to send a MMS message. All the other aspects of the phone works flawlessly, SMS works great, all apps work as intended, etc etc. The only problem is the MMS issue. I'm also using the stock messaging act if that makes a difference! Any help would be greatly appreciated!!
    Phone Info:
    Make/Model: Motorola Bravo (unlocked)
    OS: Android 2.2
    Carrier: Straight Talk Sim
    Thanks in advance guys!
  2. #2
    user7618's Avatar
    Posts
    ROM
    CleanROM ICS
    Default
    Try updating your prl.
    From your homescreen: menu>settings>system updates>update prl
    Sent from my HTC Evo 3D
    This post has +3 to topic derailment.
