1. Raneesh's Avatar
    I have samsung galaxy anycall(Korean market) SHW M100S, but now Blutooth is not switching ON after getting 2.3.4 update.PLs help me.Is phone not support for 2.3.4. OS ?
    But BT is working without a SIM.pls explain.
    04-10-2012 05:02 AM
  2. Devinator's Avatar
    You mean it wont turn on and show up in your notification area? Or will it not even do that?
    Try going into Manage Apps and clearing data, cache, etc., from anything that might be in there with Bluetooth.
    If it does show up in the notification area, but, you just can't connect a device, have you tried multiple devices?
    04-10-2012 08:54 AM
  3. Raneesh's Avatar
    Yes...bro..
    I tried it several times...Is upgrading to 2.3.6 will solve the issue?
    I don't know...
    When I press the "Turn On Bluetooth"..it is starting to turning on and then suddenly turn off.(But this issue is not exist when I remove the SIM).
    pls help...
    04-18-2012 05:02 AM
  4. Devinator's Avatar
    Are you running the stock ROM? If not, were you having the issue with the stock ROM? If you are running stock, have you always had the issue with the phone, or, did it just randomly start? If it randomly started, maybe a factory reset is in order. If you always had the issue, I'd get a replacement phone.
    Also, I doubt an upgrade is going to solve your problem. It's pretty basic functionality that was probably ironed out long ago for all phones, but, I wont say it couldn't fix it. Can't hurt to try if you have an update available.
    04-18-2012 08:13 AM
  5. Raneesh's Avatar
    What u meant by Stock...I really use this phone for 2-3 week without any hazard.Issue is happened when I remove the google acc and add a new one.But BT is working well when SIM card is not present.I also tried with many SIMs but issue is exist.I want to know 2.3.7 update will solve the problem?
    My friend said, Reset the phone without a SIM will recover the problem...It is the last thing to do...
    04-19-2012 05:19 AM
  6. Devinator's Avatar
    By stock I mean did you root the phone and put a custom ROM on it or is it as it was when you got it? Well, it sounds like you know what caused the issue. I have no idea if that update will sole your problem, but, I would say, no, it wont. I would factory reset your phone and use whatever Google account you want to use right in the beginning. I have no idea why something like that would cause Bluetooth problems, but, either way, I think a factory reset is in order. If after that, it still doesn't work, and, the phone is only a couple of weeks old contact your carrier to get a new phone.
    04-19-2012 08:06 AM
  7. Raneesh's Avatar
    Brother, I tried to reset the phone without SIM.But it won;t solve the BT problem.Sometimes BT is working properly when I switch ON to OFF Airplane Mode(all wireless off), and then i can use BT well.But again It will not work if phone is restarted.
    This Android device has the following OS specifications.
    Model : SHW M100S
    Firmware version: 2.3.4
    Kernel Version : 2.6.35.7
    Baseband version:M100S.EF14.2254.ST
    Build Number : GINGERBREAD.EG04
    By upgrading OS to 2.3.6. update or inserting Custom ROM will solve the problem? Do you know any other forum that I can get a help?
    04-24-2012 06:23 AM
  8. Devinator's Avatar
    You can try XDA.
    But, if you are having an issue like this and the phone isn't that old, I'd contact your carrier and get it replaced.
    04-24-2012 08:09 AM
  9. Frederick Cordero's Avatar
    this is not actually a custom rom, this is a cooked rom that can only be flashed thru odin only and have no recovery included, u can flashe a cook rom if ever u are rooted or not
    Hope that helps!!!
    04-03-2014 12:16 AM
  10. Frederick Cordero's Avatar
    that is a relock carrier from the manufacturer, insert a true valid sim and that issue will not appear again...
    I hope that helps!
    04-03-2014 12:23 AM
