DEAL OF THE DAY: Save 60% on the LLOYD Flex Case for LG Nexus 4!
Results 1 to 5 of 5
    Default Phone to Phone Direct VoIP
    I'm going on a cruise, and want to do a direct IP to IP VoIP session between the wifes phone and mine.
    D2 CM7
    Epic 4G CM9
    please suggest an app.
    VoIP or Jabber, possbly a ZeroConf deal, ideas?
    If I really need a server will have a laptop with me. jsut avoiding a jabber server or asterisk.
  2. #2
    Rukbat's Avatar
    Posts
    ROM
    AreaROM 3.0 or CM7.0.1
    Default Re: Phone to Phone Direct VoIP
    That depends on where the cruise will be going, or what provisions the ship has. You'll need a server that you can access. About the only phones I know of that could communicate phone to phone without a server are the Nextel Direct Connect phones.
    Buy a couple of cheap Motorola or Uniden walky talkies and you can communicate as well as a phone-to-phone connection with no server needed. (IOW, you won't get from deep in the interior of the ship to deep in the interior of the ship - phone or walky talkie - unless the ship maintains wifi service - in which case you can use Skype.)
    found BlueFi Phone, make s direct IP based calls over wifi or Bluetooth, and used ZeroCOnf for discovery it looks like,
    With static IP's and the ships wifi I think It might work.
    Also download 3CX Free server, just in case
  4. #4
    If you looking sth for free, you can try our Vippie :-) and please, give us some feedback ;-)
  5. #5
    Maybe you can use walkie talkie APPs ?
    •» Tip: Never rush to download any APP "Updates", read the feedback for a few days so that you can see if other people are having issues with it and/or changes to permissions or other you may not want! Always use a Back Up APP!
    •» Free DropBox! Back up to & Sync your Phone to your Computer Free! Always have your stuff when you need it with @ Dropbox . 2GB Plus account is Free! Plus earn up to 500 Mb's for each referral! Up to 32GB Free! http://db.tt/szmjeyX
