Results 1 to 5 of 5
    Irvgotti's Avatar
    Posts
    ROM
    Stock Sense 4.1.1
    Default help me make a decision
    OK well last Christmas my dad bought me an iPad (big no) but I really don't use it. I want something from android. Right now I'm looking for something with decent specs nothing mind blowing. I just saw the galaxy tab 2(7.0) is going for 250. What's the screen like? Should I just hold off for the nexus tablet or should I spend big bucks on the transformer prime? I'm not new to android but new to this site. I came here because the android central community is the best. I'm open to all choices (money isn't a problem) but if I don't have to spend 400$+ it would be great. I'd only use the tab for social media, recording short clips , and watch movies. So can you guys please help me?
  2. #2
    Rukbat's Avatar
    Posts
    ROM
    AreaROM 3.0 or CM7.0.1
    Default Re: help me make a decision
    That's a very personal decision. If I were in your shoes I'd probably go for a Note.
  3. #3
    clodfelterac's Avatar
    Samurai Dev
    Posts
    ROM
    IllusionB / OM
    if you dont need it in a rush... check out the ubislate7+... theyre on back order... i preordered mine so i should get a ready to ship email sometime this month... decent device at a fair price... :-)
  4. #4
    srkmagnus's Avatar
    Posts
    ROM
    Calkulin 2.7/Desperado
    The Galaxy Tab 2 7" should be a decent device. If you are looking to get the most bang for your buck you might want to hold out for the "Nexus" tablet rumored to be in the works. It won't hurt to hit your nearest retailer and see how the new Tab functions and make your own opinions based on actual use.
    Irvgotti's Avatar
    Posts
    ROM
    Stock Sense 4.1.1
    Thanks guys. Yeah I never though about going to play with one in a store.
