DEAL OF THE DAY: Save 60% on the LLOYD Flex Case for LG Nexus 4!
Results 1 to 2 of 2
    Default Need help to create Android img file
    Hi, I am working in a school and we have Xoom tablets for students to use in the classes. I am wondering if we could create an img file from a configured tablet and then flash the img onto other tablets.
    I've tried rooting/re-locking tablets from img files created by other people successfully but how can I create my own img file?
    Any help will be highly appreciated.
    Thanks
  2. #2
    PvilleComp's Avatar
    Posts
    ROM
    CM-7
    Default Re: Need help to create Android img file
    Have you tried UOT Kitchen?
    Another alternative is if you have clockwork recovery installed on all the units - you could set up one unit and make a backup. then load the backup on each unit. The downside is that they would all be tied to the same gmail account.
    Just some thoughts.
    Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig.
