Results 1 to 5 of 5
- 04-14-2012, 04:00 PM
Thread Author #1
- 04-15-2012, 10:48 AM #2
Re: ICS Camera Error Messages
Sounds like you should do a FDR / Hard Reset. It a common issue after OTA Updates.
I would also check the Sprint Nexus S forum, as most owners would probably post there as well as Sprint support people
Before doing a FDR Be sure to: Be sure to back up your data, know your gmail name & pass, so that you can re-download your purchases/apps from the play store with your current credentials after you reset your device.
Hope that helps
•» Tip: Never rush to download any APP "Updates", read the feedback for a few days so that you can see if other people are having issues with it and/or changes to permissions or other you may not want! Always use a Back Up APP!
•» Free DropBox! Back up to & Sync your Phone to your Computer Free! Always have your stuff when you need it with @ Dropbox . 2GB Plus account is Free! Plus earn up to 500 Mb's for each referral! Up to 32GB Free! http://db.tt/szmjeyX - 04-15-2012, 02:16 PM
Thread Author #3
- 04-16-2012, 09:15 AM #4
You can download Astro File Manager free @ google play
it has a free APP backup program
Back up to SD Card (ext)
Re-Install APPS after the FDR, you won't lose the APPs
•» Free DropBox! Back up to & Sync your Phone to your Computer Free! Always have your stuff when you need it with @ Dropbox . 2GB Plus account is Free! Plus earn up to 500 Mb's for each referral! Up to 32GB Free! http://db.tt/szmjeyX - 08-04-2012, 01:38 PM #5
Reply
