Results 1 to 1 of 1
- 04-16-2012, 05:16 PM
Thread Author #1
Samsung HM3700 BlueTooth Headset +Voice to text and Voice Command
Hello, i just got this headset, and the main reason i even got a BT headset is so that when im typing i can use the voice to text feature, i cant seem to get this to work, my headset is paired and i can hear nearly everything from it fine, my voice calls go through it fine, however my voice to text promts are still using the phone mic
EDIT
Ok after some testing it seems even Vlingo does not use the BT mic as the inputLast edited by rexxcastle; 04-16-2012 at 05:44 PM.
Reply
