1. patpumphrey's Avatar
    Where do my bookmarks go
    04-17-2012 12:36 PM
  2. PvilleComp's Avatar
    They are stored in a database in data/data/com.android.browser/databases
    You need to use an sql viewer to see them.
    There is an app in the Play Store called Backup Bookmarks, but it does not say if it requires root or not. There are also a bunch of backup apps in the Play Store that do not require root that will backup bookmarks.
    Hope this helps.
    And BTW - Welcome to AC!
    04-17-2012 07:55 PM
