my galaxy pop s5570 is dead.. pls help me..
sachin panchal
hiii.........
i had rooted my samsung galxy pop mini s5570 and rooted successfully.
then i install "ROM MANAGER" and then install "clockworkmod" inside it.
then i selected "backup current ROM" option in ROM manager. it shown me popup with "backup name" and as i pressed "ok".. my mobile dead and not starting now..
pls pls help me..
thnx...
If this works like my old Thunderbolt... you should be able to boot up into hBoot (the white screen), then select Recovery and try it again. If I remember correctly, you might want to Pull the battery for a minute, put it back in, then press the Volume Down and also the Power button... this should boot up into the hBoot. This should give the option to go into Recovery or select Boot up.
Reactions: sachin panchal
thanks for your replay..
i had tried to do so , but it is not displaying anything.
not even backup light or any type of vibration..
Ok... First, hold down the Volume Down button for a second... keep holding it down, then press and hold the Power button... you need to hold both down for at least 10-15 seconds to get this to boot up... of course this is IF this is the way this device boots into the hBoot screen (a white screen that shows if you have S-On or S-Off).
Ashok Dharshan
