Results 1 to 3 of 3
- 04-19-2012, 10:28 AM
Thread Author #1
ATT vs Verizon?
Just wondering which provider works best in Europe? Thanks.
Give yourself, to the Dark Side! - 04-19-2012, 10:35 AM #2
- 04-24-2012, 05:06 AM #3
Re: ATT vs Verizon?
Remember ATT are GSM phones so you can buy a sim card for overseas, pop it in and away you go.
Verizon only has limited world phones as it is a CDMA network native to the US.
I could be off a bit, but even though I have Verizon, ATT would be the better option.
Reply
