Help guys,SGS2 after factory reset,dont start
roolis
Hello,just bought Samsung Galaxy S2,the previous owner had a lot of stuff installed,i think also custom Rom(i gess so),to clear all unneeded stuff just made factory reset,after that only SGS2 i9100 logo appears and stays like this.I red that it could happen cause of custom rom,but what should i do now?does that method with DL09 for Fascinate to get back to stock fits my case?iplease guys,give me some advice what to do?thanks in advance
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
Turn off the device and hold volume up + power on. A recovery should come up and you'll have the option to factory reset among other things. Select factory reset and see if it boots up from there. If not, then you'll need to search the device forum for Odin and factory images to restore it. Only use files meant for your specific device since installing something else can cause damage.
akbarramadhani12
