How do I uninstall the NFL ap?
There is no "uninstall" when I open this. If the only way is to "root" this, is there someone in the Chicago area I can hire? I am not adept at that type of thing and don't want to ruin a new phone that is already causing more problems than I had with the previous droid I own.
Thanks,
Circulating
Re: How do I uninstall the NFL ap?
Thanks,
Circulating
That guy from Chicago is in jail now. He got caught on the last job I hired him for.
Two ways...
1) Google Play > Menu > My Apps > Scroll to NFL Mobile > Select it > press Uninstall.
2) Menu > Settings > Applications > Manage Applications > All Apps > Scroll to NFL Mobile > Select NFL Mobile > press Uninstall.
-Frank
Sounds like the app was pre-installed when you purchased the device. The only way to delete it is to root and manually enter the /system/app directory with a file explorer with root permissions to remove it.
What device do you have? There are many auto root scripts to help with the process. Check the root forum for the device.
Thank you Frank and Srkmagnus. Hmm...the best I could do was uninstall the updates and then hide the icon. I have a Motorola Droid 4. As I said above, I'm not up to "rooting". I had no choice but to replace my old Droid, but the longer I have this one, the less I'm liking, let alone enjoying it.
Frank, people like you make forums worthless. clearly your response indicating that he can simply uninstall will not work, that is if you took half a second to think about the question that was posted. simply uninstalling it is not possible, you have to root the phone. That said I don't know anyone in Chicago area that can do this.
The NFL mobile app is often preinstalled on Verizon phones. As people have mentioned here, you can't uninstall this kind of bloatware unless you root your phone. However, if your phone's Android system is 4.0 or above (i.e., Ice Cream Sandwich or Jellybean), you can Disable bloatware. Under Settings/Apps/All Apps, find NFL Mobile. Uninstall any updates first, then see if you get the option to Disable.
Again, this is for Android 4.0 and above. If you have Gingerbread or below, you can't Disable apps.
Michael and B. Diddy are correct. Verizon preinstalls this app. As soon as I got my new phone the app updated automatically and file size went from a couple of megs to 15+ mb. I removed the update manually and disabled it but a couple weeks later I checked the app and guess what, the app reloaded the 15mb update. Looks like I'll be rooting the phone.
BK
DNA by HTC
That's odd, BK. Was it re-enabled somehow? Mine stays disabled and not updating. You may want to make sure the auto updates are turned off in Play too.
