Results 1 to 1 of 1
- 04-22-2012, 11:41 AM
Thread Author #1
Issue syncing multiple calendars.
Is there a limit to the number of Google calendars (from one account) you can sync with your phone? I was able to sync my phone with my Google calendar without issue. At first I had only my default calendar and a separate one for birthdays, and they showed up and have been syncing without issue.
Then when I decided that i wanted to have separate calendars for concerts, sporting events, work events, weddings/parties, ect. but these calendars are not showing up on my phone in the list of calendars to choose from for syncing in the settings options for my calendar.
I have looked at the sharing options for these calendars on Google on my computer and they are the exact same as those two that are showing up on my phone.
Just some specifics on my phone in case it will help.
Samsung Epic 4g (Sprint)
Running stock non-rooted Gingerbread 2.3.6
I have had my android phone for a while now and I noticed this issue before but just didn't really care but now that I am I actually trying to use my Google calendar more it is becoming a real annoyance any help would me much appreciated.
Reply
